Mobile Number starting with 6
Status: Closed · Asked by Medialabs18 India on · 0 views
WhatsApp is not accepting mobile numbers starting with 6. any suggestions
Which app you're using to send Whastapp Messages It depends on that as well.
I am using WhatsApp Official Cloud API to send WhatsApp Message
Check the instructions on its action step, in which format it requires the mobile number and based on that use Text Formatter or Number Formatter to format the number.
