brunourmalmiranda
- Your Task History ID
- IjU3NjMwNTZmMDYzMDA0MzE1MjY1NTUzMjUxM2E1MTY1NTQzNyI_3D_pc
Hello, i have to things that are having a strange result on Moloni integration: (Im using Moloni sandbox account)
Here is my workflow link: https://connect.pabbly.com/workflow...IBjtaTgoOVwEEdwEYBysDAAF7VhtUL1cSCTpfAQcvUTA#
Thanks a lot for your support.
- Moloni "Create Customer" action
I am encountering an issue with the Moloni integration, specifically with the "Create Customer" feature among others. Despite ensuring all mandatory fields are filled in for the "Create Customer" action,
I am met with the following error message:
"Forbidden
No company_id received, please refer to the following guide for more information: https://www.moloni.pt/dev/?action=getApiTxtDetail&id=17"
I have verified that the company_id is indeed present and correctly selected. Any assistance in resolving this issue would be greatly appreciated.
- On Moloni "Custom API request Data (Beta)
Being beta version i understand that this one doesnt have support... however just asking because if moloni is not integrated on the bullet above or this one i can't recomend pabbly connect to my client.. thanks for understanding
on one for example moloni
+countBySearch
I seams that the parameters field is not working because if i use company_id and the search parameter and i always get the same result and not the filtered one where the "search" parameter is not doing nothing.
