MONDAY - PABBLY ISSUE
Status: Open · Asked by k2trix on · 0 views
k2trix — Question ·
k2trix — Reply ·
All my workflow trying to get Monday values have the same issue.
I'm running the same workflows for months without any problem, and i didnt change anything.
Can you please check what is wrong with Monday or Pabbly ?
k2trix — Reply ·
This is an emergency, i really need your help !
Grebom.b — Reply ·
I too am having an issue with the integration, the API connection is active, and the Board is available, but none of the Groups n the board are available any longer. I tried resetting the connection with a new API token, and there is no change.
PLEASE HELP!
Please allow us some time to look into this issue. We will get back to you with an update soon.
Pabbly_Nikahsatu — Reply ·
The integration still error, do you have estimated time?
Arshita — Reply ·
Hey @Pabbly_Nikahsatu
At the moment, we do not have an estimated time for resolution. Our team is actively working on addressing the issue, but it may take some time.
We appreciate your patience and understanding in this matter.
optired — Reply ·
same issue here. following this thread.
"Type mismatch on variable $board_id and argument board_id (Int! / ID!)"
Pabbly13 — Reply ·
Hey @k2trix , @Grebom.b , @Pabbly_Nikahsatu , @optired !
Sure, we know the concern and the tech team is working on it,
Once done, we'll update over here.
It seems the issue is fixed, Can I confirm is the issue fully fixed or only fixed some of it?
The necessary changes have been implemented, and the Monday.com action step should now function as intended. We can confirm that the problem has been resolved.
Thanks for your patience!
