Move Facebook Leads to Funnelkit Automation
Status: Closed · Asked by Stacy on · 0 views
Stacy — Question ·
Is it possible to connect Pabbly to Funnelkit using web hooks?
If so, can you please provide step-by-step instructions.
Thank you!
Hi @Stacy,
Yes, it is possible. You can follow the steps given in the help text shared below to achieve your use case.
Stacy — Reply ·
Hi @Stacy,
Thanks for your reply.
We're trying to move new Facebook Ad leads into a Funnelkit/Autonami automation.
Are you providing instructions for us to accomplish that via Webhooks?
For this use case you need to use 'FunnelKit: Create Contact' action event.
Establish a new connection with your FunnelKit account using API Key and Site URL.
Read the following instructions to understand how you can create the API Key.
https://forum.pabbly.com/threads/funnelkit.17761/
I am not sure of what you mean by accomplishing this using webhooks. There is no need for webhooks for your use case.
Stacy — Reply ·
We don't have access to the FunnelKit API yet, and our leads are coming in quickly. So I was looking for an alternate way to make the connection.
Is there any way to get a copy of the FunnelKit "add-on" plugin besides via FK's support? (It appears that FK's support staff may be on holiday today.)
Hey @Stacy
Regarding your concern, we suggest reaching out to the FunnelKit support team. Alternatively, please inform us of how you intend to handle the request via webhook, allowing us to assess its possibility.
Stacy — Reply ·
Hi @Supreme
We now have the FunnelKit API and have entered it as shown in the screenshot you shared above. The connection is still failing. The " Data In" is successful. The "Data Out" is not. Screenshot attached. Help is appreciated!
The error message you're encountering from the Facebook Lead Ad API is as follows: "Unsupported get request. Object with ID 'xxxxxxxxxxxxxxxxx' does not exist, cannot be loaded due to missing permissions, or does not support this operation. Please refer to the Graph API documentation at https://developers.facebook.com/docs/graph-api."
This message suggests that there may be an issue with the requested object's ID, insufficient permissions, or the operation not being supported. You can refer to the Graph API documentation for further guidance.
Please check the following thread on your concern and make sure that the Facebook account you have connected with the trigger event has ownership of the lead ad form means you need to be the admin of that Facebook lead and have to grant all the permission to access the Lead ad form. You can try making a new connection for your Facebook Lead ad and make sure you have granted all the permission of the respected page.
