Move part of workflow and / or reorder elements
Status: Closed · Asked by amicici on · 0 views
Hello, since I've created some really complex nodes, is there any way to move part of the nodes without recreating them from scratch?
Another question
How can I reorganize the management order within a route window, so as to assign the new priority directives?
Hey @amicici
You cannot rearrange the action step in your router step.
You can rename the action step by using the rename button in your router step.
Sure but non this cut or paste other position complete date.
If you're referring to moving the step up or down, then as of now its not possible to doing so.
