Multible Pabbly Iterator actions problem
Status: Closed · Asked by edwardzev on · 0 views
edwardzev — Question ·
Hi there,
I have airtable automation that allows client to upload up to 4 graphics in one record. Then I upload them to dropbox.
In order to get particular attachment link I use iterator. And it works fine.
The problem is that if client uploaded not 4, but 1,2 or 3 files, the automation doesn't continue beyond last iterator that has file. How do I make automation to continue even though iterator returns empty value.
Please check the screen shot
and this is automation history.
Hey @edwardzev
We looked into your workflow and it seems like due to multiple Iterator action step your workflow executed every data coming from your API an additional of 5 times with other iterator action steps with their additional data 4,3,2,1 Iterator times each.
Therefore you have exhausted all your tasks in that, so as far we understand your concern we would recommend you to use the router action step with the Individual Iterator action step.
Kindly try this at your end and let us know if that works for you.
