Multiple connections to same tool
ter_ter
Hi there. Does Pabbly support scenarios where you set up connections to different instances of the same tool? I.e. I have two Gmail account and two Notion accounts and I want to connect to all 4.
Hey @ter_ter
Yes, you can add multiple conditions for the same applications.
