Multiple plans with Multiple currencies for same product
Is it not possible to create different plans with different currencies for the same product?
I wanna add an INR and USD plan for the same product.
Is this not possible?
V
Vipin Mishra
Hello Deepak,
We would like to inform you that we provide the option of Multicurrency to our users through which you can add different currencies in your account and also you can create different plans for the same product in different currencies.
Settings >> Multicurrency >> Add Multicurrency >> After Adding >> Login Now (for another currency account).
Once you add the another currency then it will create another account for that currency known as Secondary Account so there will be two accounts one with the Currency with which you have registered on Pabbly Subscription Billing (PSB) will known as Primary Account and another will be the Secondary Account with the new currency.
So, you have to create same Products on both the accounts and then you can create same plan with different currencies in the same product as well as you can create different plans with different currencies under the same product.
Hope the above information will be helpful, for further queries fell free to reach us.
Regards,
Vipin Mishra
so techncially, I cannot have the same product page with different currencies.
There will be 2 product pages, 2 checkout pages with different currencies.
this is really sad.
V
Vipin Mishra
Hey Deepak,
Sorry for the inconvenience but currently this is not possible on our system.
For further queries please reach out to us.
Regards,
Vipin Mishra
ok. is there a way to clone a plan and product from CurrencyA to CurrencyB, since almost everything about the product and plan is going to remain the same, except the value?
V
Vipin Mishra
Hello Deepak,
Currently we do not provide this feature on Pabbly so you have to Manually create the Products and Plans with another currency since Cloning of Plans is only possible for the same product under the same currency.
For further queries feel free to reach us.
Regards,
Vipin Mishra
