Multiple Product Events Over Time - Right Way to Structure Workflows
Status: Closed · Asked by kurt on · 0 views
hi, if I'm passing events from my product into pabbly. like say responses to an onboard, and then later events inside the app. These events don't all take place at the same time.
how do I need to structure this inside Pabbly workflows? can I batch it all in one workflow, batch together certain elements, or have every single event and its attributes be a different workflow?
thanks!
Hey @kurt
Your use case is not clear at all, so kindly elaborate on your usecase once briefly. So that we can look into it and guide you accordingly.
ok @Supreme sorry if that wasn't clear enough. perhaps its too basic what I'm not understanding, so its confusing.
I want to pass events from my web app product to pabbly.
examples: responses to an onboarding survey or events inside the app like feature usage.
example does each event needs its own unique Pabbly workflows, like this? https://d.pr/i/8mr9DG
or when we have form all the attributes are created at once, like this https://d.pr/i/c6Kd0P
but when the events can happen discretely, at different times (example https://d.pr/i/KCYIvH ), even though they are all for one customer do they all need to be a stand alone Pabbly workflow?
so example:
'onboard_web' event is one Pabbly workflow?
and
'contact_support_click' is a second Pabbly workflow?
thanks for your help!
Hey @kurt
You can try Router Action step instead of making different workflows, you can simply make individual routes according to the event type and the new entry will always redirect to its individual event route by simply creating a condition.
You can refer to the following video tutorial on how you can create a router action step. Kindly try this at your end and let us know if that works for you.
@Supreme watched the router video, but will this work if the events are not coming in all at the same time? like the form in the example happens in one submit, but if the data is passed in different times are routers still the right approach?
Hey @kurt
Your workflow will take the data at any instance and if the router condition gets full-filled then the router step will also process your data accordingly.
Kindly give it a try and let us know if you get stuck at any step.
