Multiple products in clickbank
Status: Open · Asked by Ezy on · 0 views
I am trying to connect Clickbank with my Systeme account. I have many products in my Clickbank account. Each product should trigger an access for the buyer to a specific course in my systeme.io account.
However, I can't find any instructions on this.
As of now, there are 10 products in Clickbank. I notice that on my Clickbank's Instant Notification URL section, there are 10 fields. Does that mean I need to follow in order of the product list? eg: Product 1 is for 1st field. Product 2 is for 2nd field, and so on.
Please advise.
Thanks.
Regards,
Zai Adi
Hello @ezymastery
Thanks for the update.
To help you better, please share the workflow URL from your Pabbly Connect account where you're trying to connect Clickbank with Systeme.io. We’ll review your setup and guide you accordingly.
If you're okay with it, we may also need access to your Pabbly Connect account to check the workflow directly. You can give permission by replying with this message:
You have my permission to log into my Pabbly Connect account and edit the workflow (if required). Here is the registered email address associated with it: [your email]
Looking forward to your reply!
You have my permission to log into my Pabbly Connect account and edit the workflow (if required). Here is the registered email address associated with it: ezymastery @ gmail.com
Hello @ezymastery,
Thanks for your message and for granting access.
You don’t need to use all 10 Instant Notification URL fields in ClickBank for each product. Just one webhook URL (from your Pabbly Connect workflow) is enough. This single URL will receive order data for all your products.
Once the data reaches Pabbly, you can set up filters or conditions to check which product was purchased and then trigger the correct action — such as enrolling the buyer into the specific course in your Systeme.io account.
Let us know if you face any further issues.
Thanks.
Any videos on how that can be accomplished? I can't find videos on doing this or something similar to what you have mentioned:
"Once the data reaches Pabbly, you can set up filters or conditions to check which product was purchased and then trigger the correct action — such as enrolling the buyer into the specific course in your Systeme.io account."
Please advise.
Hello @ezymastery ,
Thank you for your response.
We’ve reviewed your workflow and noticed that in the Systeme.io: Grant Access to Course step, there are two key fields to configure:
- Course ID – the specific course you want to grant access to.
- Contact ID – the Systeme.io contact to whom you want to grant that access.
Now, based on the data coming from the Data Transformer (Pabbly): ClickBank step — which processes the webhook response — we’re receiving the ProductTitle and customer details, but not a specific course ID. So, to proceed, we’ll use the ProductTitle to determine which course the buyer should get access to, and then use the customer’s information to create or fetch the contact in Systeme.io.
Could you please confirm if this matches your intended use case — that is, granting access to a specific course in Systeme.io based on the product purchased via ClickBank
Once confirmed, we can guide you step-by-step.
Ok to make things simpler, I have deleted one of the workflows. Now there is only one.
The purpose is to Grant Access To The Course:
Name of Course on Systeme: Crushing Limiting Beliefs
Name of Product on Clickbank: Crushing Limiting Beliefs
Item Number of Clickbank: 2
You mentioned: "Could you please confirm if this matches your intended use case — that is, granting access to a specific course in Systeme.io based on the product purchased via ClickBank?"
Answer: Yes! :)
