My automation is not working
Status: Closed · Asked by Durkis on · 0 views
Durkis — Question ·
Hello!
I have set up my first automation. It is using tasks, getting notifications from Plutio and reporting that it's created a task in Plutio, but I cannot find this task. Can anyone help? screenshot attached.
Hermes — Reply ·
@Durkis With regard to Plutio, this workflow is very dangerous!
I can't see what which actions you selected in the plutio api manager, but without filters or routers such a workflow can easily create 1000 tasks a day.
Plutio triggers a lot of webhooks so you need to filter very good when you want a task to be created.
Best regards,
Hermes
Connect with me on LinkedIn
