my pabbly connect flow is not working
Status: Closed · Asked by babu on · 0 views
hi team, this is the flowhttps://connect.pabbly.com/workflow/mapping/IjM4MDMyNCI_3D pls check it.. my customer is not getting email confirmation.. every time we submit a form they are not getting mail confirmation.. pls do needful as soon as possible
Hi @babu,
I have checked the history for this task in the workflow and found that emails are not sending because of the error Message "Recipient email missing".
Could you please check in the form if you have the Guest recipient email id column present or not? If not then kindly create it in the form and map it in the workflow so that your workflow can run seamlessly.
