Mypipeline product enrollment
Status: Closed · Asked by Ganga Narayan Das on · 0 views
ganganarayan.rns — Question ·
I am struggling since more than a month, tried several things, searched all over the net, but could not find any clue how to do this.
After a successful payment from Instamojo or Razorpay, the customer needs to be added to the product purchased.
I tried, search opportunity, could not find relevance
I tried, update opportunity, there is no way I could find the opportunity to update.
I tried with zapier, its just 2 step for both instamojo and razorpay. But I do not have zapier subscription, and also it is expensive. Since I am already with Pabbly, I want this to happen.
So far I could not make it through Pabbly.
Please make a video or make the necessary changes whatever required, so that the enrollment happens smoothly.
Please update.
Thanks and Regards
Ganga Narayan Das
Hey @ganganarayan.rns
As we can see from your workflow, you are not passing the Opportunity ID correctly instead you are passing the name of the user. So, kindly use the "Search opportunity" action step to add the user with its associated Opportunity ID.
Moreover, in the Contact ID field, you need to pass the Contact Id with the help of the "Search Contact" action step instead of the Contacts' name which is already been mentioned in the help text.
So, kindly do the corrections and try again.
ganganarayan.rns — Reply ·
Did those changes as suggested.
Let's see if that works. I will update.
