MySQL > could not connect ?
Status: Closed · Asked by rabbitdezign on · 0 views
rabbitdezign — Question ·
I got an error message "wrong host / wrong port " by creating a new MySQL Connection for the Webhock ( Form Submit ) Action
The host is "mysql.57" Port is "3357"
Of course I used the correct Username/Passwort
Why I cannot connect?
I was using the Trial / demo Account, to test the feature,
I dont think to buy it, when this does not work
Pabbly — Reply ·
Looks like your database is IP restricted. Please whitelist Pabbly Connect IP at your end and then try connecting. Here's Pabbly Connect IP - 44.224.102.169
rabbitdezign — Reply ·
Thank you for the answer, you were right, my SQL Database wasn't configured for "external access".
After enabling this feature, it works perfectly
