Need assistance to TRIGGER a flow after AI assistance
Status: Open · Asked by Socioshoot by Ashit Malik on · 0 views
socioshoot — Question ·
Hello, I create a flow which started with 2 options
1. Redirect to inquiry form
2. Speak to AI assistant
Once AI assistance takes over, it chats well but if the user is typing Hi, hello or any keyword which is part of my flow trigger it is not restarting. I want help me making 1 flow which can be triggered again if a user types certain words and then select options again, i have plan to use 3 ai assistant in 1 flow, say user gets option 1, 2 and 3, option2 and 3 are different ai assistant, it could be possible that user selects option 3 first but want to explore option 2 or 1 later, i am not trigger my flow again when it is assigned to ai assistant automatically.
is there any way around that?
Hello @socioshoot,
Thank you for reaching out.
To assist you further, could you please share the email address associated with your Pabbly Chat Flow account and the name of the specific flow connected with the chats you're referring to
Additionally, in order to investigate and make any necessary changes on your behalf, we request your permission to access your Chat Flow account. Kindly reply with the following statement in your next message:
“You have my permission to access my Pabbly Chat Flow account and make changes if required. Here’s the email associated with my account: [your email]”
Once we have your confirmation, we’ll proceed accordingly.
socioshoot — Reply ·
Hello @socioshoot,
To assist you further, could you please share the email address associated with your Pabbly Chat Flow account and the name of the specific flow connected with the chats you're referring to?
You have my permission to access my Pabbly Chat Flow account and make changes if required. Here’s the email associated with my account: [email hidden]. Flow name is Flow1
Hello @socioshoot,
Thank you for the clarification.
We understand that you’ve created a flow where users can choose between chatting with the assistant or selecting other options. However, once a user opts to chat with the assistant and the AI is enabled for that conversation, only the AI will continue to respond, even if the user later sends a keyword that would typically trigger a flow. In such cases, the flow will not be re-triggered.
Currently, this behavior is by design. However, we understand the need for more flexibility, and we’d like to let you know that the feature to prioritize flows over AI Assistant is already in our pipeline. Once this feature is developed and made available, we will announce it or inform you directly.
We hope this clears up the situation. Let us know if you need any further assistance in the meantime.
okay, another follow up question, if the user is chatting with ai assistant, and 24 hours passed, and then he replies, what will happen, will it trigger the flow again as new or will ai respond, what will happen? will it trigger a default 1st message like thing?
If the user replies after 24 hours, the AI assistant will respond to their message. It will not trigger the flow again as a new conversation, nor will it send the default first message.
The assistant will continue the chat based on the conditions mentioned in your statement.
is there any way, a different chat assistant can reply if i have 3 or 4 different chat assistant
Soumya Tripathi — Reply ·
Hello @socioshoot
Yes, you do have the option to assign different AI Assistants to chats. However, please note that the assignment needs to be done manually.
Soumya Tripathi
Rate your support
[QUOTE]
[/QUOTE]
