Need Assistance with Scheduler
Status: Closed · Asked by LUDIFU.com - Let Us Do It For U on · 0 views
What if I wanted Multiple Timings in One Sheet...
Instead of Creating one Workflow Per Time Slot
Is there a way to Enter Multiple Time Slots on the same sheet.
AND the Workflow basically triggers the events based on the correct matching time slot given in the sheet
Right now, I have one workflow per time slot.
Trying to find a better solution
Hey @zest83
You can add as many Delay action steps before the Google Sheets: Add Row step according to your time to the same sheet.
I did not understand - How will Adding Delays Help?
In terms of what I have asked!
Possible to explain with an Example or something
Hey @zest83
Please check out the following short recorded video for your better understanding and can use the sample workflow for your logic.
https://connect.pabbly.com/workflow/share/D0cHNVQfUjdUHQV_AVYMbQsfV34GTAVTVDMDEQ##
Hey
Really appreciate the efforts taken to make this video
Yes, it does make things simpler for me
