Need Help Connecting Interakt + Pabbly + Claude AI for WhatsApp Auto-Reply Automation
Status: Closed · Asked by Lavika Jain on · 0 views
Hello Pabbly Team,
I am trying to build a WhatsApp AI chatbot workflow using Interakt, Pabbly Connect, and Claude AI.
Workflow Goal:
- User sends a WhatsApp message to our Interakt number.
- Interakt sends the incoming message to Pabbly Connect.
- Pabbly sends the message to Claude AI via API.
- Claude generates a response.
- Pabbly sends Claude's response back to the user through Interakt.
Issue:
I am facing difficulties configuring the API connection and workflow. The setup is not returning or sending Claude's response correctly. I am unsure whether the issue is with:
- API authentication,
- Request/response mapping,
- Claude API configuration,
- Interakt response setup, or
- Pabbly workflow configuration.
I would appreciate guidance on:
- The correct setup process for Interakt → Pabbly → Claude AI.
- Required API configuration and headers.
- Proper response mapping from Claude back to Interakt.
- Any sample workflow or documentation for this use case.
I have attached screenshots of my workflow and configuration for reference.
Thank you for your support.
Hello @impressioncart,
Thank you for sharing the details of your use case.
To help us investigate the issue further, could you please share the workflow URL of the Pabbly Connect workflow you have configured
Once we have access to the workflow, we can review the setup and identify the specific point at which the issue is occurring—whether it is related to API authentication, request/response mapping, Claude AI configuration, Interakt setup, or the workflow configuration itself.
After reviewing the workflow, we will be able to guide you on the appropriate steps to resolve the issue.
We look forward to your response.
