Need help for a case - Send follow up message when there is no update after X days on notion
Status: Closed · Asked by Surya Dharma on · 0 views
Hi there, I'm trying to make a workflow between Notion - Whatsapp that sounds like this:
1. Trigger: "Need To Be Collected" checkbox is ticked
2. Response:
- Send a WhatsApp message to customer
- Send confirmation message to Notion page
3. If the "Collected" checkbox is not ticked within 5 days
- Send a follow up message from WA
My current setup is
Workflow #1
1. Trigger : Notion - update database item
2. Filter: only continue if "Need To Be Collected" checkbox is ticked
3. Send Whatsapp Template Message
4. Router
- If message success: get the current date -> update status Success to notion page
- If message failed: get the current date -> update status Failed to notion page
Workflow #2 - here's where it got complicated
1. Trigger: Notion - update database item
2. Filter: only continue if status is Success
3. Delay for 5 days
4. Send Whatsapp Template Message
5. Router
When I use this setup, it's not working properly. Can anyone help? Should I just put the delay on workflow #1 after message is success instead?
Thanks guys!
