Need help in figuring this automation with Spayee & Pabbly
Status: Closed · Asked by advaitdanke on · 0 views
advaitdanke — Question ·
Hello!
Pabbly & Spayee are officially integrated.
So I have this automation setup for one of my freebie product 1 on my Spayee platform. When a user enrolls in the course, the webhook data goes to pabbly and adds the user details in the respective product 1 email list.
But now the issue is,
When I have a product 2 and I want a product 2 automation similar as above, I cannot set up the automation for it. (or maybe I don't know the process)
If I create a new workflow inside pabbly connect using the new enrollment option, it creates a NEW webhook url which I have to replace it inside Spayee.
And I think,
If I replace that then my product 1 automation becomes invalid.
Is there any other process or any advanced workflow which I have to implement?
Pabbly — Reply ·
You can simply make use of webhooks section available inside Spayee account. Just add the webhook URL and select the event as per your requirment -
Please try at your end and let me know if you stuck at any step.
advaitdanke — Reply ·
Thank you soo much for the reply!
But I don't have this webhook feature. I have the tier 2 plan.
Pabbly — Reply ·
No problem. You can make use of a data forwarder to pass the same webhook response to another webhook response. I have updated your workflow. Please have a look over it -
Further just put the filter for course name in your other workflow as shown below -
Wow amazing! Thank you soo much for the fast response!
I will test the workflow and reply back with the working!
So I tested this,
Even when a test user enrolled for the product 1 workflow, he went into the product 1 email list as well as product 2 email list.
Have I done something wrong in the filter process?
Regards!
Pabbly — Reply ·
So I tested this,
Regards!
Yes, filter setup is wrong. You need to enter the course name manually and make the filter fix like as shown below -
Please send us the course name for both workflows.
Pabbly — Reply ·
Thanks. We have updated the workflow. Please check once how we have made the filter setup based on the course name you have provided.
Now both of the workflows are not working o_O:ROFLMAO::ROFLMAO::ROFLMAO:
Pabbly — Reply ·
Please test the workflow now.
