Need Help in Sending Autopost update from Webpress to Telegram
Status: Closed · Asked by Study Cafe on · 0 views
Need Help in Sending Autopost update from Webpress to Telegram. I am Using this video as a tutorial. Everythig is set but messages are getting send when i do click on Save & Send Test Request not automatically.
What should i do so that messages can be posted automatically instead of clicking on Save & Send Test Request Everytime.
Need Help in Sending Autopost update from Webpress to Telegram. I am Using this video as a tutorial. Everythig is set but messages are getting send when i do click on Save & Send Test Request not automatically.What should i do so that messages can be posted automatically instead of clicking on Save & Send Test Request Everytime.
Once any post is updated over your WordPress, your workflow will start to work automatically and then a message will be sent to the Telegram channel. You don't have to click over the "Save& Send Test Request" button every time as you're currently doing.
Please try this at your end and let us know how it goes.
Hi Team,
Above Solution Worked. But the Problem is that we want to send only Publish posts from Wordpress to Telegram.
But in our Word press files are also there we have E-Commerce is also there. So Now Everything is going on to Telegram. We want to send only Posts to Telegram.
Please help in resolving this also.
Hi Team,Above Solution Worked. But the Problem is that we want to send only Publish posts from Wordpress to Telegram.
Looks like you have already added the filter step for that -
