Need Help whmcs2sevdesk
Status: Closed · Asked by germanvps on · 0 views
germanvps — Question ·
can anybody tells me, how to connect whmcs to sevdesk?
Arshita — Reply ·
Hello @germanvps
Please refer to the following video tutorial to understand how to connect Whmcs with Pabbly Connect. I request you to please try it once from your end and do let us know if you get stuck in any step, so we can check it for you.
youtube.com/watch?v=s_YX5muVMLk
To connect with Sevdesk, you need to select Sevdesk as an action step and then choose the action event according to your need.
Screenshot for your reference:
germanvps — Reply ·
Hello @germanvps
I get this error:
"objects": null,
"error > message": "Contact: set correct number abort",
"error > code": null,
"error > data": null,
"error > exceptionUUID": "fcb21c53-8c28-4ef6-8070-271f5cf24de6"
Arshita — Reply ·
I get this error:
Can you please specify the application where you are facing this error?
Additionally, I have observed that you were using the deprecated version of SevDesk's "Add Contact as Person" feature.
Therefore, I have reconnected with SevDesk and you will need to remap the fields and try again. Kindly verify if you are still facing some issues.
