? Need Help with HMAC Signature Verification in Pabbly Webhook
Status: Open · Asked by OlivierFrench on · 0 views
OlivierFrench — Question ·
I'm sending a form from my React website to a Pabbly Webhook and want to secure the transmission using an HMAC SHA256 signature.
? Frontend: I'm generating the HMAC signature with a secret key and sending it in the "X-Signature" header.
? Problem: How can I verify this signature in Pabbly before processing the data?
If anyone has implemented this verification or knows how to do it, I’d appreciate any guidance! ?
Thanks in advance! ?
Hello @OlivierFrench,
Could you please confirm if you're looking for functionality to decode the secret key Please refer to the attached image for more details.
OlivierFrench — Reply ·
YES... IT'S TO SECURE MY WEBHOOK... DO I CREATE IT BEFORE AFTER THE WEBHOOK..IN AUTOMATSIATION
Currently, we have the feature to hash a string into HMAC SHA256 format. However, your requirement seems to have the ability to decode an HMAC SHA256-encoded key back into the normal string, you can submit your request on our Integration Request Board:
https://pabbly.featureos.app/b/Feature-Request
