Need help with sending failed data to sheet
Status: Open · Asked by saroosh7 on · 0 views
saroosh7 — Question ·
We pass Fb and LI leads to Salesforce via pabbly, but we get a lot of failed tasks, because a lot of our leads already exists in our CRM, so can we create a workflow of a workflow, means, let's take the example of the below workflow, in that can we pass data of all the failed tasks to a sheet?
Hi @saroosh7,
You can use the 'Pabbly Connect Manager: New Workflow Error' trigger step in your new workflow to capture errors from another workflow. Then, use the Google Sheets action step to add those error details to your spreadsheet.
youtube.com/watch?v=Kl1iy26wxZY
Lorenzo Giacomini — Reply ·
does the "Pabbly Connect Manager" also catch the Partial Failed errors?
Lorenzo
Hello @meetab,
Yes it do capture Partial errors.
