Need Pabbly video connecting Calendly with Zoho CRM create Meeting/Task record and connect to existing Contact
Status: Open · Asked by Rhondalyn Svoboda on · 0 views
rcsvoboda — Question ·
Need Pabbly How To video connecting Calendly with Zoho CRM create Meeting/Task record and connect to existing Contact via Contact email address
Hey @rcsvoboda,
Could you please elaborate a bit more on your use case, for me to gain a better understanding of your workflow?
rcsvoboda — Reply ·
Using Pabbly integrate Calendly with Zoho CRM Meeting or Task Module
Calendly Invitee Created
Creates Calendly data in Zoho CRM - Meeting/Task Module
Although we don't have a dedicated video for it, the use case you are describing is possible. Kindly refer to the attached screenshot for a clear understanding of how the workflow will be configured.
I am attaching these videos for your reference. While the steps may vary slightly from your specific use case, the concept remains the same.
youtube.com/watch?v=HOOuuGFvgXM
youtube.com/watch?v=dhTiB4h9lKg
