Need Technical Help
Status: Closed · Asked by Aim Revolution on · 0 views
aimrevolution777 — Question ·
Hello Team,
I hope you are doing well,
My Self Mehul & I'm using pabbly connect from the last 3 to 4 months & I'm happy with the service.
I'm facing 1 issue, but I did not find the solution so I'm asking the query here.
My issue is,
I have created a workflow, it's main work is Captur the payment & Send them Google Drive access of product A.
But When I'm Selling another product B using another workflow then my old workflow is sending Product A Access to my Product B customer.
So please give me a solution ASAP, using any of the methods
I can connect Remotely as well via AnyDesk.
So please Provide the Solution
Thank you
Pabbly — Reply ·
Hello Team,
My issue is,
Thank you
The team has replied to your ticket #366867 Need Technical Help.
Please check it.
