New issue with Workflow not fully executing
Status: Open · Asked by Dan Cook on · 0 views
Your Workflow URL: https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjcwNTZkMDYzNzA0M2M1MjZmNTUzZDUxMzMi_pc
Task History ID: IjU3NjUwNTY0MDYzMjA0MzQ1MjZjNTUzMDUxMzQ1MTYyNTQzNzBmMzUi_pc
I have added one example of the workflow not triggering fully.
It shows as "success" in the history but it didn't fully run, it just recevied the webhook and never did the following steps.
Prior to January this never happened but these last two months it has happened frequently.
Hi @dan90,
It appears this was a one-time occurrence, as none of the other task histories are showing a 0-step workflow execution.
Could you please try re-executing the workflow and let us know how it goes If the issue persists, we will investigate further.
