Nifty PM not selecting Project ID dynamically from Lookup Table
Status: Open · Asked by Jus on · 0 views
Consent to Access & Modify: I don't authorize Pabbly Support to log in to my account.
In the Nifty PM app, the Project ID is set to populate the value from the 'result value' of the Lookup Table (Pabbly) app. However, it does not even though the history shows the correct result value from Lookup Table, it seems to default to the same project value from the response (test).
Found the solution: Use 'Task Group ID' instead of 'Project ID'
Hi @Jus,
Thank you for the update. We’re glad you were able to resolve the issue.
