No response when connecting to WooCommerce
Status: Closed · Asked by Bruce on · 0 views
Bruce — Question ·
I am trying to update WooCommerce from a Google Sheet. When trying to connect I get the error related to no response after 15 seconds.
I can connect and update the spreadsheet when products are added or updated in WooCommerce. The only issue is from Google Sheets to WooCommerce.
Does anyone know if there is anything else that needs to be set up to connect?
Kind regards,
Bruce
Hey @Bruce
Kindly cross-check your WooCommerce account credentials and then try reconnecting it again. Perhaps you might be adding a trailing slash at the end while passing the "Website URL".
