Not able to add country code
Status: Open · Asked by saroosh7 on · 0 views
Hi i am unable to add UAE country code to my workflow
Workflow URL
https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZlMDYzZTA0M2Q1MjY5NTUzYzUxMzci_pc
Hello @saroosh7,
Could you please specify the particular action step where you are trying to add the UAE country code but are unable to do so This will help us better understand the issue and assist you accordingly.
Looking forward to your response!
So, in the above workflow i have connected our UAE fb ads accounts, in that workflow we have multiple filteration steps, one of them is phone number, you see, people don't usually put correct info in the forms they submit on Fb ads, for eg, i have attached the just 4 different type of number we recieve in a campaigns, as you can see, one had 0 at the start, next one don't have to country code (which is 971) 3rd one is correct, but 4th one is where we got+ sign.
We want to change the data to 3rd value, country code without + sign and the rest of the number
[TABLE]
[TR]
[TD]050 548 9612[/TD]
[/TR]
[TR]
[TD]504652910[/TD]
[/TR]
[TR]
[TD]971508239128[/TD]
[/TR]
[TR]
[TD]+971 52 509 8551[/TD]
[/TR]
[/TABLE]
Hello @saroosh7,
You can add a Number Formatter action step to your workflow and use the Spreadsheet Formula called RIGHT to extract the last nine digits of the number, removing the country code.
Refer to the attached image for more details. While adding this step, replace 11 with 9 to ensure you get the correct number format.
Let us know if you need any further assistance!
Hi this is working with numbers that have country code, but we also get a lot of numbers that doesn't have country codes, like this 050 548 9612, or 504652910
Hello @saroosh7,
The formula will work for numbers that do not contain a country code, as it extracts the last nine digits of the number. However, if your number contains spaces, you can use the Replace Text action to remove them first. Once the spaces are removed, you can map the response from that step to the previously suggested step.
Refer to the attached image for more details. Let us know if you need any further assistance!
