Not able to capture data from active campaign
Status: Closed · Asked by Deepak Bajaj on · 0 views
Dear team,
Just created a workflow for active campaign to another action but after connecting AC to Pabbly and clicked save and test request now it's not capturing the response i have tried many time
I need the solution asap
I have attached the error screenshot
Hey @Rahul Chaudhary
Can you please reconnect the trigger event once and then try again? You may also refer to the following video lessons' last part for the same.
Thanks for the replay It was started working.
