Not able to connect to Airtable
Status: Closed · Asked by 1uptick on · 0 views
1uptick — Question ·
The connection has been working fine all along, but all of a suddenly not able to connect to Airtable, error message "invalid_client".
Please help
TimPonting — Reply ·
+1 on this - existing connections are not working today, and setting up a new connection triggers the error "invalid_client" - this is pretty mission critical for us :cry:
Arkadian Capital — Reply ·
Same error do we have a fix yet?
Please allow us some time. We will get back to you as soon as the issue is resolved.
pachuko00 — Reply ·
Hello, yes same for us. For about 6 workflos. I'm getting Invalid authentication token when checking history & when trying to reconnect you get invalid_client. This is critical for day to day operations...
Nico — Reply ·
Same invalid_client error here.
dongtranle — Reply ·
Same here invalid_client error
Nico — Reply ·
The problem is not on the Airtable side, the problem is on the Pabbly side, because I did a test connection to Airtable in Zapier and it connected.
EricTsang — Reply ·
Same situation
Nico — Reply ·
Hello.
Any update?
We’re pleased to inform you that the issue has now been resolved. Kindly update your Airtable connection under the Connections section and try executing the action again.
If you encounter any further issues, please don’t hesitate to let us know—we’re here to help.
For anyone coming back to this thread, looks like it's now been fixed :)
Bearing in mind it was 3AM in India when I posted I'm pretty happy it's back up already, thanks Pabbly!
Edit - I hadn't refreshed the page and seen the update that it had been fixed like 90mins ago! Thanks again team :-)
Hello @TimPonting,
Thanks for the update!
Nico — Reply ·
Thank you!
