Not able to send messages through Ai Sensy
Your Workflow URL
https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZkMDYzNDA0MzY1MjZlNTUzMzUxM2Ei_pc
Your Task History ID
Consent to Access & Modify
I authorize Pabbly Support to log in to my account and make changes to the specified workflow for troubleshooting.
Hi Team,
I am using AiSensy, but in Pabbly Connect I can only see the old connector “WhatsApp by AiSensy”.
I need the NEW “AiSensy” connector which supports WhatsApp Template Message sending and shows the Template dropdown.
Please enable the new AiSensy integration for my Pabbly Connect account.
Thanks!
ArshilAhmad
Hi @Arjun Sharma,
Currently, this is the only action step available for the AiSensy application. If you would like to see the AiSensy action step updated in Pabbly Connect, you can submit your request on our dedicated platform:
https://roadmap.pabbly.com/b/Update-Existing-Application
Our integrations team will review your request and, if possible, implement the desired changes to the AiSensy action step.
Arshil Ahmad
🌐 Pabbly.com
👉Rate your support
