Not Workflow Work
Hi Team,
I want implement incoming call (Indian Time 7pm - 9am Everyday data). which should be saved in my crm.
I have created workflow but not work.
Workflow Name: Test Incoming Call (Created on 20 July)
Regards,
Devesh Rai
(Sheopals)
Hey @sheopalsmarketing
As we can see from your workflow, it is in the switched-off condition, kindly try it after switching on it.
Hey @daniel.grant@financeplann
Kindly use one Linkedin account connection in your Linkedin action step to avoid the "The token used in the request has expired" error message.
Though we have reset all your free tasks for the last time. Kindly use it wisely.
Please use one account connection of LinkedIn and remove all other connections.
sachinites
I am also getting this error. I need to post on two linked in account. All was good 2 days ago, then this started surface. pls help.
If those connections do not belong to the same account, they should function properly. Additionally, try to maintain the latest connections by removing outdated and unused ones.
