Number Formatting using Number Formatter
Status: Closed · Asked by James Buchanan on · 0 views
James B — Question ·
I'm getting one format on one workflow giving me
04-888 8888
And another on another workflow
04 888 8888
So when it goes to look up the number is failing because of the -
Detailed loom below, looking to get them formatting the same on two seperate workflows.
https://www.loom.com/share/d852bfe41bed450c99f5444a571f92cc
Hey @James B
If you are getting the Phone number on a particular phone number label then you can use "Text Formatter" for the same.
