OpenAI Extracting Content from a PDF/Image using Structured Output Lambda Error
Status: Open · Asked by Mohammed Usman on · 0 views
usman — Question ·
having an issue when i am trying to extract data fields from an invoice using OpenAI Extracting Content from a PDF/Image using Structured Output. Getting an error invalid response from Lambda, 500.
Hello @usman,
Please provide us with the workflow URL where you're facing this issue so we can better look into the issue and assist you further.
Hello @usman,
We have added an extra action step to your workflow to make the file publicly accessible, as the file you were using was not accessible. However, the PDF size exceeds 1 MB, which seems to be causing the issue.
To resolve this, please try:
  • Using single images instead of a large PDF.
  • Using a file with reduced file size.
Kindly test and let us know if it works fine for you.
