OpenAI Structured Output "Generate" not appearing
Status: Open · Asked by arnold muganhu on · 0 views
arnold muganhu — Question ·
I am trying to generate a structured output prompt for my workflow but the "Generate" prompt is not appearing even when I`m logged in my OpenAI account.
arnold muganhu — Reply ·
Thank you for your response.... I wish to extract text from a pdf using openAI, however my effort to generate a structured output on their page is not allowing me as the section that says "TRY IT OUT" and "Generate" are not appearing. Please see attached screenshot....I tried logging in into my account and it still doesn't appear.
If you're on Windows, try pressing CTRL + Shift + R to perform a hard refresh in your browser and check if that resolves the issue. For Mac users, press Command + Shift + R to hard refresh the browser and see if that fixes your issue.
Thank you, unfortunately this did not resolve the issue
Hello @arnold muganhu,
Since this issue is occurring specifically with the OpenAI platform, we recommend reaching out to their support team for further assistance. Please keep us updated on how it goes.
Jayeshpatel78 — Reply ·
i have also same issue, please update me
