Order test gateway.
Status: Closed · Asked by CertDev on · 0 views
I want to pull the woo-commerece data to google sheets , so I singup with Pabbly and try to connect by creating workflow and trigger it with order updated ,Now how can i do a test submission/record so that the data can be recorded here in the webhook response. In wordpress there is no option order test gateway.
Your help will be appreciated.
Thanks.
Hey @CertDev
Please check out our tutorial videos, for a better understanding of your concern.
- https://www.youtube.com/channel/UCVA5GKy8qpDxQR5xSt_zcJg/search?query=woocommerce%20google%20sheets
youtube.com/watch?v=gUEBh_C0E9s
Kindly try this at your end and let us know if that works for you.
Thanks!
what do i do i want to display all the orders from past to till date
Hey @CertDev
To add all the past orders to your Google Sheets, please check out the following screenshot -
from this i only get that mapping entry. could you please assist me in a call?
Hey @CertDev
We have created the workflow in your account kindly try once to add all your past orders in your Google Sheets. Then you can turn it off when your orders get added.
Why this shows an error
Hey @CertDev
It looks like you have changed your credentials or maybe passed the wrong credentials. Also please do check that you have activated the JSON Basic Authentication.
