Output to google sheet is unusual from GHL. Iv'e done it the same way 10000x
Status: Closed · Asked by joshbuss on · 0 views
Hey guys
Im recieving this in my google sheet. I've never experienced this before
1. First Name : Josh
I have attached the workflow and gsheet example.
Hey @joshbuss
Kindly follow the steps below in order to fix your concern:
1. Hard Refresh the workflow by pressing (Ctrl +F5).
2. Re-map the corrupted fields in the action steps.
3. Save the step and test your workflow.
Thank you this worked!
