IlanFreeman
I have set up a Pabbly Filter using the "And" function. My understanding is that if both of the filters are correct, it will go through; however, if only one of the 2 is correct, it will stop. However, I see that if either is correct, it will stop.
My use case is:
If the Service category is not equal to "xxx"
And
If the service transaction is not equal to "0"
My use case is:
And
