Pabbly and Iubenda Consent Solution
Status: Open · Asked by lgn81 on · 0 views
lgn81 — Question ·
Hello, I would like to connect the subscriptions of my new leads in Kartra with the creation of new Consent Solution in Iubenda, like I'm actually doing with Zapier (see image here below). I can't find Iubenda in Pabbly. Isn't possible to do in Pabbly?
Hi @lgn81,
If you want to see Iubenda application added to Pabbly Connect, you can submit a request on our dedicated platform:
https://pabbly.hellonext.co/
Our integrations team will look into your request, and if possible, add the desired application to Pabbly Connect.
In the meantime, you can try using API by Pabbly module to achieve your use case
youtube.com/watch?v=bmf4och_kTk
