Pabbly and Monday.com - Connecting Photos in Wix Forms
Status: Closed · Asked by Miami Friendors on · 0 views
Hey @Miami Friendors
Could you kindly provide the link to the form and inform us about the type of field you have set for the image field in your form?
Miami Friendors — Reply ·
Thank you for your response. Here is the link to the form although you would need to create a free account in order to access it. https://www.miamifriendors.com/account/marketplace
I've included a screenshot of it as well.
The image field type is a "File Upload Field" Max 15MB.
From your workflow, it appears that the Wix application doesn't include any image URLs in the trigger response. Instead, it sends the image in encoded form.
Thank you, but I don't understand. Is there a way I can fix that? How would I make it work so that it's sent to Monday?
Since the Wix Form doesn't send the image URL in the trigger response, the images won't be able to process further.
You can contact Wix support to see if they can provide the image URL instead of encoded image data.
Understood. Thank you.
