Pabbly and Twillio
Status: Closed · Asked by souldsad on · 0 views
I got an error when I connect Pabbly with Twillio
Was this page helpful?
Warning - 12200 this is the error
sourceComponent "14100"
line "1"
ErrorCode "12200"
LogLevel "WARN"
Msg "Content is not allowed in prolog."
EmailNotification "false"
parserMessage "Content is not allowed in prolog."
cols "1"
Schema validation warning
Possible Causes
Misspelled verbs
Incorrect case for verbs; TwiML is case-sensitive, so works, but will not
Misspelled or unknown attributes
Unknown or unexpected nested elements.
Possible Solutions
Check the line and column reported by the warning to see what part of your XML response caused the complaint
Verify that your application server is accepting and properly responding to any custom parameters you may be passing
Error Description
The provided XML does not conform to the Twilio Markup XML schema. Please refer to the specific error and correct the problem. ## Warning - 12200
Request Inspector
1 comment
Like
Comment
Share
Hey @souldsad
Kindly reauthorize your Twillio account and then try the Twillio action step again. If you still face any difficulties.
Please do share your workflow name in which you are facing such an issue, so that we can assist you accordingly?
Thanks!
