Pabbly API Body field missing
Status: Open · Asked by Bryan Grasso-Shonka on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZjMDYzNzA0Mzc1MjZmNTUzMjUxM2Ei_pc
How do I input the content I need for the body of an API message? Its missing in the classic builder
Hi @SnackGuy,
It appears that you have selected Custom Request, which should give you the option to enter the entire body in the Data field.
Arshil Ahmad
?Rate your support
