Pabbly API Body field missing
Status: Closed · Asked by Bryan Grasso-Shonka on · 0 views
Hi @SnackGuy,
It appears that you have selected Custom Request, which should give you the option to enter the entire body in the Data field.
Arshil Ahmad
?Rate your support
