Pabbly Connect 2 Questions
Status: Closed · Asked by caleb.cheatham on · 0 views
caleb.cheatham — Question ·
Hello everyone. I have two questions that I can't figure out. I'm trying to do the replace text feature and look for multiple types of words to remove and make them {{blank}} I'm able to do one word, but I cannot figure out how to do two. Another is when I get a webhook from lead connector. I can see contact company name, but when I edit it and try to send it back to lead connector. There is no field for contact company. Any help would be much appreaciated
Arshita — Reply ·
Hey @caleb.cheatham
Regarding your first concern about the "Replace Text" action, if you want to replace multiple words, you will need to add a separate "Replace Text" action step for each word you wish to replace.
Regarding the concern about the company name field, I have made a note of it and forwarded it to our team. They will check and provide you with an update.
Arshita — Reply ·
Hey @caleb.cheatham
We have added a field of Company name in the Lead Connector: Update Contact action event. I kindly request you to check and let me know.
caleb.cheatham — Reply ·
Yes, this works. Thank you!
