Pabbly Connect: Adding values without Re-Capture Webhook Response
Status: Closed · Asked by moshik on · 0 views
moshik — Question ·
I am using An Elementor Form with more than 100 fields.
From time to time I need to add new fields and\or change the order of the fields in the form.
In order to add the new fields from the form, I need to re-capture the webook response.
Is there any way I can re-capture Webhook Response without losing the appended values?
Hey @moshik
If you are changing the fields from your Form then we would recommend you to not make any changes after capturing the webhook response.
If you do, then you need to recapture the webhook response again and again.
