Pabbly Connect and KoboCollect
Status: Closed · Asked by ministergh on · 0 views
ministergh — Question ·
I have been receiving data through Kobocollect and i want to find how i will be able to connect kobocollect to be able to send notification for data submitted
ministergh — Reply ·
Apart from the SMS options list, can i use a localised SMS API from Ghana to be able to send SMS through google sheet
https://devapi.fayasms.com/
Hey @ministergh
As of now KoboCollect API is not available on the platform, but you can post the request to add the trigger and action event here - https://pabbly.hellonext.co/
For your concern, you can make use of API by Pabbly action step in your workflow. You can also refer to the following video tutorial on how you can use the action event.
youtube.com/watch?v=M-oU-yG-CCU
