Pabbly Connect and Wave
Status: Closed · Asked by wpeace on · 0 views
wpeace — Question ·
I'm trying to automate creating an invoice in Wave (waveapps.com) and while the connection to my account works, Pabbly does not appear to be able to access my customers. I also can't enter the customer name manually. Wave does not recognize what is entered in that field.
The field shows nothing is selected and nothing is available. Attempting to refresh does nothing.
I don't have the same problem with Integromat or Integrately as they both pull the customer information.
Hey @wpeace
We have tested the "Wave: Create an Invoice" action event and it si fetching the customers from the respective Business correctly.
Kindly cross-check the business that you have at least one customer present or not.
