Pabbly Connect Flow Executing Twice Simultaneously - Help!
Status: Open · Asked by Virakhshi on · 0 views
Virakhshi — Question ·
Task History ID: IjU3NjUwNTY5MDYzMzA0MzU1MjZhNTUzNDUxMzI1MTYxNTQzOTBmMzAi_pc , IjU3NjUwNTY5MDYzMzA0MzU1MjZhNTUzNDUxMzI1MTYxNTQzNzBmMzki_pc
Hey everyone,
I'm encountering a strange issue in my Pabbly Connect account and I'm hoping someone here might have some insight.
I have a specific workflow set up, and I've noticed that it's consistently executing twice at the exact same time. This is causing duplicate actions and obviously isn't ideal.
Has anyone experienced something similar with Pabbly Connect? Any ideas on what might be causing this double execution, or what I should be checking to troubleshoot it?
Thanks in advance for any help or suggestions!
i have attached last 2 task history for more clarification
Hi @Virakhshi,
Razorpay triggers are based on descriptive webhooks, and we do not have any control over the data sent by the source application to Pabbly Connect. If Razorpay sends the data twice, your workflow will also be triggered twice.
You can test this by connecting your Razorpay account to webhook.site—you will receive the data twice there as well.
youtube.com/watch?v=V0eih93WSj8
We recommend reaching out to Razorpay's support team to understand why the data is being sent twice from their end.
