Pabbly Connect: Invalid format from an automation with Formaloo and Heartbeat.chat
Status: Closed · Asked by Famai Gastaldi on · 0 views
I tried to create an automation from submitting a form from Formaloo (trigger) -> create user in Heartbeat community (action).
I received an error for "invalid format" after I tried to upload a jpeg file to the form and then use that field for that user profile.
The image I used for the test was a square (800 x 800), 221 KB, JPEG file which works fine when I uploaded manually for my new profile picture on Heartbeat.chat and according to the Heartbeat API documentation, Jpeg is fully supported, a file under 5MB works as well.
No idea why it was invalid format?
Hey @Famai
Can you share the image URL which you are passing, so that we can check on it and help you accordingly?
Hey @FamaiCan you share the image URL which you are passing, so that we can check on it and help you accordingly?
Hi, I attached the file that I used to upload here:
Can you share the Image URL instead of the attachment? Also, are you passing a static image URL or passing the URL from the trigger response?
https://s3.amazonaws.com/formaloo-en/s/2023/8/2/dycvWJj1d7cc4773-7055-4863-8a7f-4fe4009f3243.jpeg
Here is the error I received:
About the image, I used Formaloo form which allow me to upload an image from the form, I believe it is URL from the trigger response? (it is a URL pointing to the image stored on Amazon S3 which generated by Formaloo)
Hey @Famai
From the Heartbeats' API documentation, it is evident that they currently only support Base64 encoded URLs. Therefore, instead of providing an Image URL, you must pass a Base64 encoded URL.
Hey @FamaiFrom the Heartbeats' API documentation, it is evident that they currently only support Base64 encoded URLs. Therefore, instead of providing an Image URL, you must pass a Base64 encoded URL.
Is there any automation option in Pebbly connect I can set up to generate from image URL to Base64 encoded URL?
Is it possible to use convert API to convert from image URL to Base64 encoded URL? or do I need developer for this.
Apparently, there is no API available to convert the image URL to base64. But if you get any API to convert the Image URL to Base64 then you can use the API by the Pabbly action step for the same.
